I am trying to create a Whatsapp bot after inputing my variables and click on deploy then it will load and then late brings error
I was checking but it seems that you have solved your problem, haven’t you?
No I haven’t
It seems related to your application. You need to check the configuration of your service or your application. Also, note that you reached the usage limit on your Free database for this month.
