Tenstorrent N300 device not detected by userspace tools (pyluwen/TTNN)
Hi,
I’m having an issue with my Tenstorrent N300 GPU instance where the kernel driver sees the device, but userspace tools cannot enumerate it.
Important: This was working fine a few days ago. The issue started after my account was suspended for verification. I completed the verification process and the account is now active, but the TT device detection has been broken since then.
What’s working:
  • Kernel driver loads successfully: Loading Tenstorrent AI driver module v2.5.0
  • Device is found: Found a Tenstorrent Wormhole device at bus 0000:02
  • sysfs entry exists: /sys/class/tenstorrent/tenstorrent!0
  • Card type correctly shows: n300
  • PCI device accessible: vendor=0x1e52, device=0x401e
  • Can mmap BAR0 and read hardware registers
What’s NOT working:
  • pyluwen.detect_chips() returns
  • pyluwen.pci_scan() returns
  • ttnn.open_device(0) fails with: TT_FATAL: No chips detected in the cluster
  • tt-smi shows: No Tenstorrent devices detected
Environment:
  • TTNN version: 0.65.1rc16
  • pyluwen version: 0.8.1
  • Kernel: 6.1.62-tenstorrent-gpu
  • Driver: tenstorrent v2.5.0
What I’ve tried:
  • Multiple redeploys
  • Creating /dev/tenstorrent0 device node manually (c 246 0)
  • Setting up hugepages
  • Various environment variables
The kernel sees the device but pyluwen/UMD cannot enumerate it at the userspace level. Any help appreciated!
Thanks!
