xjsv
1
According to the docs here: Deploy a Web Scraper using Puppeteer, Node.js and Docker on Koyeb - Koyeb
We are suppose to use the chromium that is already installed:
executablePath: '/usr/bin/chromium-browser',
Unfortunately I am facing the following issue
Could not resolve the browser instance => TimeoutError: Navigation timeout of 30000 ms exceeded
When I run it locally I don’t have any issues.
xjsv
2
As per @Sebastian here Failed to launch the browser process in puppeteer - #4 by Sebastian_Wiewiora
I redeployed your Docker image on Micro instance and it worked, so it looks like Nano has not enough resources to run it.
xjsv
3
After updating the instance size everything is working as intended.
Thanks to @Sebastian!
