Koyeb web serivce unhealthy
Without having changed the backend (repository), the koyeb web service stopped working. I am using the free tier.
It’s like it’s very slow.
After build it’s starting but after 5-10 minutes it says unhealthy.
Instance created. Preparing to start…
Starting download for Harbor
Download progress: 100% |++++++++| (1.5 KiB/s)
Same issue with me
@Gab_B it seems that your service is ok now. What was the issue exactly?
@Mrxxxx It seems that your service is misconfigured, you need to add Procfile or set run command.
