i’m trying to deploy an node api using nest and i’m getting this erro on runtime, someone know what I have to do?
Hi @Victor_Hugo,
The problem you are facing is most likely caused by the memory requirements of your app. You can either optimize your app to lower its RAM requirements or upgrade to a Starter plan and choose an instance with more memory.
