HTTP health check failed
Starting download for registry01.prod.koyeb.com/k-eabb74f1-e8b3-47f4-b38e-189f5e197f69/06229197-ef9d-4b6a-a9b4-aadfd7c85352:11473992-d44b-4cc8-8268-775cd1814cae
Download progress: 100% |++++++++| (9.4 MiB/s)
Download complete for registry01.prod.koyeb.com/k-eabb74f1-e8b3-47f4-b38e-189f5e197f69/06229197-ef9d-4b6a-a9b4-aadfd7c85352:11473992-d44b-4cc8-8268-775cd1814cae
Instance is starting... Waiting for health checks to pass.
Chatbot running on http://0.0.0.0:3000
HTTP health check failed on port 3000.
i got this when i deploy my node js app using docker
this is my server snap
app.listen(PORT, '0.0.0.0', () => {
  console.log(`Server running on http://0.0.0.0:${PORT}`);
Bro, for this you need to start a GET request on the HTTP Health Check path. It’s / by default. So add it before starting the listener and use the same port in the environment and HTTP Health Check.
app.get('/', (req, res) => {
  res.send('Hello, World!');
I had same problem, what I did to solve it was:
I changed my PORT and used the same PORT (3000, in your case) in my .env file.
.env
PORT=8000
app.js
const PORT = process.env.PORT || 8000;
app.listen(PORT, () => {
  console.log("App listening at port", PORT)
Hope it works for you.
