Hi, so as stated from the documentation, it is currently not possible to to assign an apex domain for apps.
But when I went to Domain section and tried example.com, I got the following to assign an ALIAS:
example.com ALIAS something.cname.koyeb.app
So I went to my domain on Hostinger, added a DNS record with @ linking to something.cname.koyeb.app, but the verification on koyeb failed
Can you help me find out what I did wrong?
Sorry I’m fairly new to this, so my description could be a bit clumsy
Hi @Dang_Gia_Chi !
There is no need to apologize, you were right when quoting the doc. The hint in the control panel makes things unclear. We will fix this.
Except if your domain is managed by Cloudflare (which we rely on), it is not possible to assign apex domains to apps. From here, you have two options:
- Transfer your domain from Hostinger to cloudflare and add the ALIAS record from there
- Setup a HTTP redirection on Hostinger:
- Create the custom domain
www.<yourdomain>.com on Koyeb
- Create a CNAME on your provider from
www.<yourdomain>.com to <something>.cname.koyeb.app. This will make your app available on www..com
- Create a HTTP redirection on Hostinger. This will make
<yourdomain>.com redirect to www.<yourdomain>.com Input the following fields:
- Redirect:
<yourdomain>.com leave “path” empty
- Redirect to : choose “URL”
- Redirect to:
Hi @nicolas, thanks a lot for your reply. I changed my nameserver to Cloudflare and was able to assign my app to an ALIAS successfully
Is this still the case? Use cloudflare or www?
Ok, also solved it. In case anyone else missed it, you can use the nameservers on cloudflare for free and there set up the cname for Koyeb.
