The Deployment is not starting, its stuck at status: allocating resource. The region is North America.I tried multiple redeployment but its generating same error. There is no log and active deployment.
We’ve looked at it, and the deployment is now healthy.
Sorry for the inconvenience.
thanks @david for resolving it, its worked for me for sometime, but again facing the same issue, my instance becomes irresponsive. and redeployement also don’t works after that.
Hello @mayank_sati, can you describe what exactly doesn’t work? From what I see, the instance is running now.
