Hello, and welcome to this week’s changelog update! Let’s dive into what’s new:
Improved Visibility of GPU Availability
We’ve updated the Instance selector to clearly display GPU availability in the top-right corner of each Instance. Previously, availability was shown alongside GPU specs, making it easy to overlook.
Improved Billing Alert Configuration
You can now remove a budget threshold for your organization. We’ve also added confirmation messages when configuring or removing thresholds to make it clear that changes have been applied.
Enhanced Organization Selector
The organization selector now supports searching by ID when you belong to more than 10 organizations. Previously, only the first 10 were listed with no search option.
Fixed Environment Variable Interpolation
We’ve fixed a regression that prevented using the
KOYEB_GPU_COUNTvariable in environment variable interpolation.
