Eu alternatives
Koyeb may benefit as more people & companies want to move away from being dependent on the USA. In the light of that maybe it is possible to provide alternatives to using:
  • Github and Docker for deployment
  • Stripe for payment (Mollie is a good alternative)
  • Cloudflare for Domains
Hello @Nicke_Alm,
For Github and Docker when you use our CLI command koyeb deploy and select the European region, we will use our own internal registry hosted in Europe, and your code will not leave the continent.
As for other things, there are currently no plans for changing it :frowning:
